exhaust Manifold
chico
exhaust Manifold
Post by chico »
So it's time to get the Fiat back on the Road, real quick question, what is this ball bearing in my exhaust manifold purpose? I believe that I can just plug the hole but not sure. Thanks Image
124JOE
Re: exhaust Manifold
Post by 124JOE »
EGR port
plug it
and tie up you wire for the dist"dizzy"
or it will melt
someone already plugged it with a ball bearing
chico
Post by chico »
Thanks guys, I'll put a bolt into it and seal it up, the ballbearing is loose and is just rattling around and allowing exhaust to come out of the port. And yea I'll tie up that wire before it starts giving me headaches...lol
narfire
Post by narfire »
If you have a welder , perhaps try zapping the bearing a couple of times to hold it in place?
