Wide timing belt
KidDingo
Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Wide timing belt
Post by KidDingo »
Hi Everyone,
About to change the timing belt on my '81 FI. Have seen a high-performance 1" timing belt at AutoRicambi.
Anyone tried it? Any feedback on benefits? Pros... cons?
Thanks in advance.
M.
_______________________________________________
Michael
boogiedude
Your car is a: 1978 spider 1800
Re: Wide timing belt
Post by boogiedude »
You must have cam pulleys without the front and rear guards in order to use the wider timing belt
KidDingo
Post by KidDingo »
Yep. Have those.
I mean, I have the flangeless cogs.
Michael
manoa matt
Post by manoa matt »
Do you also need a flangeless auxillary pully? The 3/4" belt is just that a belt, the 1" belt is a belt and suspenders, so to say.
leeputmanjr
Post by leeputmanjr »
You need to have the aux pulley w/ flange, and the other side is guided by the main crank.
131
Post by 131 »
You don't need it. The 3/4 belt does the job perfectly well, just change it at the recommended intervals. The wide belt won't give you any more mileage before it needs replacement and makes no difference performance wise.
Mick.
KidDingo
Post by KidDingo »
131 wrote:You don't need it. The 3/4 belt does the job perfectly well, just change it at the recommended intervals. The wide belt won't give you any more mileage before it needs replacement and makes no difference performance wise.
Thanks mate. That's what I was looking for.
M.
Michael
