At what mileage after changing a head gasket do I need to retorque it?
What is the correct procedure?
But isn't the point of backing them off to make sure the proper torque is achieved while tightening? It's more likely to take more torque to break the friction to get a bolt moving than the original torque setting.So Cal Mark wrote:I wouldn't loosen them, just check the torque and tighten if needed
Remember that static friction is always more than sliding friction. Meaning that if the bolts are torqued to 55ft-lb, then a torque wrench will have to be set to a higher torque setting (say 60 ft-lb) to break it loose. Once it is moving, the friction decreases.timinator wrote: if you are ready to torque your bolts it is not necessary to back them off first.
Not impossiblevandor wrote:> >Or do you mean you should somehow determine the breakaway torque of a bolt
I think that would be nearly impossible to do, unless you are a physicist
