Idles waaay down when brakes are applied
AZ79
Post by AZ79 »
Is there a way to remedy this? I have a carbed motor, no emissions, no vacuum leaks.
Re: Idles waaay down when brakes are applied
have you confirmed that the booster isn't leaking?
AZ79
Post by AZ79 »
I thought of that right after I posted this. How do I determine if the booster is leaking?
I have two spares... How can I tell if they're in good condition without having to actually install them to find out?
manoa matt
Post by manoa matt »
With the car running, push on the brake pedal and listen around the foot well. If you hear a big hiss and the car boggs down and wants to stall you probably have a busted brake booster diaphragm.
To test your other boosters, install a length of hose on the vacumn fitting, make sure the plunger and rubber seal that interacts with the master cylinder is fully seated. Suck on the hose while pushing in on the forked rod that attaches to the brake pedal. If you can suck a bunch of air (and dust, be carefull) then the diaphragm is busted. When you suck on the hose and push in the actuating rod and vacumn remains constant then the diaphragm should be good.
divace73
Post by divace73 »
this exactly happened to me only 2 weeks ago, it was the booster.
To test the 2nd unit I acually first tested in on the engine, then cleaned and painted it, then again tested it using a vacuum cleaner, all worked, then fiannly installed in the car (without disconnecting the braking circuit) and all was great.
It would ONLY happended when the brakes where applied. Interestingly this forced me to look up how a booster actually works (you tube is great for this) which then makes you understande what is actually happenening.
When you put you foot on your brakes, you open a valve that lets air into the back side of the diaphragm (which is under vacumm when the engine is running and brakes not applied) forcing it to move forward.
Cheers David
see my >>You tube channel<<
AZ79
Post by AZ79 »
Thank you Matt, it was definitely a bad booster. I just unplugged it and sealed the vacuum port. The car runs great now, but the brakes are stiff. They do work, though.
I'll check my other ones tomorrow...
4uall
Post by 4uall »
[quote="manoa matt"]With the car running, push on the brake pedal and listen around the foot well. If you hear a big hiss and the car boggs down and wants to stall you probably have a busted brake booster diaphragm.quote]
While looking through some old posts I have come to determine that the above describes exactly what happened to my Fiona yesterday :cry: I found a diaphram online (http://www.autoricambi.us/cgi/commerce. ... ey=BR8-414) however, before I order I was curious to know how does one replace this item? :? Photos are a great help :wink:
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
Jay, it's a real pain to change the diaphragm but doable. I changed mine but the old one showed no sign of a tear or hole. Installed the new and it still would not hold the vacuum. I have another that I plan to install. If you find the key to replacing the diaphragm and making it work I would be very interested in the technique.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
grittracing
Post by grittracing »
would that be the same on a fuel injected car? and runs better when motor is warmer in warmer weather . but if I slow down fast like from 70 to 5 or 10 coming off the high way it will stall out a few times than recover and drive fine
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
How in the world did you get your booster apart? I bought a diaphram at some point, but gave up and threw it away and did a manual brake conversion. Even when I didn't care if I ruined it anymore, I couldn't get it apart. Autoricambi sells a reman for $159.
http://www.autoricambi.us/product/BR8-4 ... ufactured/
I think Vicks was advertising a pretty cheap new one, but their website won't work for me.
Trey
4uall
Post by 4uall »
htchevyii wrote:How in the world did you get your booster apart? I bought a diaphram at some point, but gave up and threw it away and did a manual brake conversion. Even when I didn't care if I ruined it anymore, I couldn't get it apart. Autoricambi sells a reman for $159.
What do you mean "manual brake conversion"? I saw the AR one (hoping to not have to spend the $ ) to fix :( Vicks has lost my business. :roll: I may just have to bring it in to a shop to have done :? Anyone have any advice?
dmwhiteoak
I had mine apart several times trying to figure out why it would not hold a vacuum. A royal pain every time. You have to compress and turn the two halves at the same time. I would go back with a little grease around the edges each time. Finally I give up and am running with booster disconnected. I have one on the parts car that I will swap with when time permits.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
4uall
Post by 4uall »
How does run without the booster connected? :? Is it not needed to make applying the brakes easier? :? What do we do with the vacuum hose/s? :?
dmwhiteoak
Jay, plug the hose end that is connected to the booster. The brakes will be a little stiff but not bad all. I have driven it everyday for the last year like this but I will replace it.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
4uall
Post by 4uall »
what did you plug it with?
