Hello everyone i am new here and just picked up a 76 124 spider . I changed the oil because synblend 5w30 its been seating for about 5 years synblend 5w30 and will do the same thing to the fuel or run it out . I got it running and bleed the cooling system because the fan wouldt kick on . I plan on replaced the plugs because its missing a bit going to replace the shocks and driveshaft center support bearing its loose . I am going to send the radiator out to get the tanks resealed or a new core installed .
Should i use rotella 5w40 in this engine or no ? Its fully synthetic and i am not sure for this old of a engine ?
I am a Mechanic but i am new to this cars so want some tips from you guys .
Need some help on what to do .
- kmead
Re: Need some help on what to do .
Rotella would be fine as it contains zinc which helps with keeping your valves and valve seats in good shape.
I wouldn't use a synthetic in this car.
The rest of your activities sound good, while replacing the bearing in the driveshaft also replace the Guibo/rubber coupling as it likely needs to be done as well.
Karl
Karl
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
Hello and welcome to the forum. I agree with Karl, no synthetic.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- Your car is a: 1967 Fiat 124 Spider
they make the rotella 5W40 in a non synthetic formulas as well. I have used it with no problem in older cars.
1964 Fiat Abarth 850TC conversion
1962 Abarth Allemano 1 liter Coupe
- 124JOE
hello and wecome
They only make the 5-40 in fully synthetic . should i run the 10-30 or 10-40 synthetic blend or or tripple protection 15-40 i think this might be too much ?
With spring coming soon i want to get this spider going .
- 124JOE
shell rotella 15w40 with zinc
thats what im going with this year
Thats what i originally got and sent it back i guess i will exchange it tomorrow . It should be fine i will only be driving it in the summer as i have other cars to drive and share the summer with so .124JOE wrote:shell rotella 15w40 with zinc
