I know.. get a manual... and i plan too
noticed recently and suddenly a ticking... thought it was the valves.. po did a rebuild on the engine so this surprised me... with research i made a make shift stethascope and found it was the exhaust manifold... all three nuts on the bottom are gone... also motor mount on that side is loose.... got the nuts .... double nutted (is that a word) the studs and have them in good and tight... just need to know how tight to make the nuts.... thanks.... matt 81 spider 2000
torque specs for exhaust manifold please
- 81SPIDERMATT
- aj81spider
Re: torque specs for exhaust manifold please
According to the shop manual the manifold nuts are torqued to 22 ft-lbs.
A.J.
2006 Corvette
2006 Corvette
- 81SPIDERMATT
thanks youaj81spider wrote:According to the shop manual the manifold nuts are torqued to 22 ft-lbs.
- opus10583
- Your car is a: 1978 CS1
Hi Matt,81SPIDERMATT wrote:I know.. get a manual... and i plan too
The (3) manuals I have say 18ft-lb.
Ciao,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- aj81spider
Mark is right. I went back and checked, and I was looking at the wrong section - 22 ft-lbs is if you have a turbo.
Sorry about that.
Although I highly recommend getting the paper one if you want a .pdf version for the short term you can get it at:
http://www.njfiats.org/joomla15/images/ ... ntents.htm
Sorry about that.
A.J.
2006 Corvette
2006 Corvette
- 81SPIDERMATT
thank you very much.... i do some tech work for office depot... got a job for them on the 5th... while i am there i will print this up... thanks againaj81spider wrote:Mark is right. I went back and checked, and I was looking at the wrong section - 22 ft-lbs is if you have a turbo.
Sorry about that.
thanks mark... 18 lbs got it.... man tight working space for that blot close to the firewall
- opus10583
First improvement I made was reclaim the exhaust system, first value I looked up was the manifold nut torque spec; it stuck with me.81SPIDERMATT wrote:thank you very much.... i do some tech work for office depot... got a job for them on the 5th... while i am there i will print this up... thanks againaj81spider wrote:Mark is right. I went back and checked, and I was looking at the wrong section - 22 ft-lbs is if you have a turbo.
Sorry about that.
Ciao,
Mark
