1979 2000 When I removed this engine/trans, I simply let the driveline slip out of the splined hole coming out of the donut.
Now, trying to reinstall the engine, I can't for the life of me get the driveline back into that hole.
I had to unbolt the ujoint at the rear end and pull the driveline off so I could set the engine/tranny in place.
After the engine was settled, I tried like hell to get that splined end to slip into that yolk, but it wasn't happening. I assume I need to take the donut off. Why isn't it going in? I even lubed the sucker.
Driveline into transmission problems
Re: Driveline into transmission problems
Can anyone offer me any pointers on this? I'd sure appreciate it.
- 124JOE
i thought they sliped right in
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
Maybe the grease is causing a hydraulic lock, this happened on my RR, i had to clean both parts spotless, hit with some wd40 and finally got them together - simple task turned into a real pain! The splines could then be greased with a gun on the nipple - i think the fiat is the same, i am terrible for not lubing the fiat because the u-joints are sealed units (the greaseable units are my preferance because i feel the need to lube them at every oil change).
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- 124ADDHE
NP. Did it work then?
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Nope, haven't tried it yet. I doubt it's a pressure lock, I only lightly coated the splines. I'll try again, then if it doesn't work I'll take the donut off.
Well, I took the donut off, and then of course it slid right in. I finally have the drive train bolted in.
I don't know why it wouldn't slide in, it seemed to be in the splines, then it would hit a stop. My suggestion to anyone reoving the transmission is to just unbolt the donut and leave it connected to the drive shaft.
