Engine ID
opus10583
Your car is a: 1978 CS1
Engine ID
Post by opus10583 »
Hi,
I have a 7/77 build '78 Spider, driver's side alternator.
I can't possibly contort to read the engine ID on the oil filter mount, and have learned I can't trust anything or anyone concerning the history of this car.
Is there some other location to read the block/engine ID from?
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
131
Re: Engine ID
Post by 131 »
opus10583 wrote:Is there some other location to read the block/engine ID from?
In a word, no! It's stamped into the side. I recently had to provide an engine number for an inspection, I couldn't get close enough to read it, but I could reach the area to give it a good clean. I was then able to take a photo with a digital camera and blow up the image to read the number.
Mick.
DocGraphics
Your car is a: 1978 124 spider
Re: Engine ID
Post by DocGraphics »
It is a pain to see for sure (mines a 10/77) what I did was cleaned the area good & then wiped the area with a dirty rag to fill in the number w/ dirt/grease & then contorted to see with a flash light from all kinds of different angles (me & the flash light) till I was able to make out all the bits (never all at one time)
I verified that it was the correct engine to the car....NOW IF I HAD ONLY WRITTEN IT DOWN!!
I like the camera idea! & maybe work a mirror into the scenario
Don Raugust
opus10583
Re: Engine ID
Post by opus10583 »
Thank you both!
That's what I've been afraid of. But you've both given me very good tips!
...Is this the only reason to move the alternator to the passenger side?
Thanks again,
Mark
131
Re: Engine ID
Post by 131 »
opus10583 wrote:...Is this the only reason to move the alternator to the passenger side?
The alternator is not hard to remove or refit, maybe 1/2 an hour all up. Pull it out, get the number, write it down, refit alternator.
Mick.
manoa matt
Re: Engine ID
Post by manoa matt »
Mark,
Check out pages 4-5 of this wonderful document: http://www.mirafiori.com/faq/fiatcarb_july2004.pdf
blurple124
Re: Engine ID
Post by blurple124 »
I always find it is much easier to get a camera into those places than a head! Take as many pictures as you can in there and look at them on a computer later, you are bound to capture the number in one of them.
Charlie
1997 Jeep Wrangler TJ Sport
opus10583
Re: Engine ID
Post by opus10583 »
manoa matt wrote:Mark,
Hi Matt,
I knew where to look, found the seeing daunting.
Mark
opus10583
Re: Engine ID
Post by opus10583 »
Hi,
A couple of sessions with a toothbrush and engine cleaner, plus a camera (and sharpen and +contrast and negative) did the trick; thank you all.
My '78 has the correct engine: The mythic, unreferenced 132A1.040.6 ...That would not have been my bet.
Now I can order the correct lightened flywheel to go with my new old transmission.
Thanks again,
Mark
