Pictures
md88plt
Your car is a: 1979 Fiat spider
Pictures
Post by md88plt »
Anyone know how to post pictures on this site?
tartan18
Your car is a: 1975 Fiat 124 Spider
Re: Pictures
Post by tartan18 »
Here is a tutorial on how to post pictures on this forum.
http://www.fiatspider.com/f08/viewtopic ... res#p37831
I actually use Flickr but the principle is the same -- using an offsite picture hosting server. Good Luck.
Jim MacKenzie
1975 Fiat Spider
azruss
Re: Pictures
Post by azruss »
I use a site called Hosting Bytes! 2.0. It is free and doesnt require a sign up. when you load the site, you can browse for a picture and then download it. They give you several options for transfering. I just copy the first line and paste it into my thread here.
As mentioned, if the pix you post is wider than 700 pixels, then you wont get the entire picture. that part is a PITA. All my pix are bigger than that, so i shrink them with a photo editor and will usually stick a few pictures together in the small format as a single file, then i can copy and paste the file.
