I have to keep all of my emission lines for two more years to pass our state regs. I need some help with the circuits.
Under the fuel inlet towards the bottom is a vent pipe, where does that go?
I have a teed line. The line runs from a electrovalve across the front of the engine to a valve/pot. Where the does the perpendicular line go?
On the underside of air filter coming off the breather tube is a small vent pipe, where does the go?
There are two vent pipes on the manifold, one vent leads to the bottom of the carb by the mixture screw, where does the other go?
Does anyone have pictures or diagrams of the vacuum tube circuits which include the electrovalves? Thanks for any help. Paul
32adf vacuum lines 1978
- 124JOE
Re: 32adf vacuum lines 1978
Yes, but I did not see diagrams or explanations for any of these questions. Did I just miss it all? psg
- 124JOE
no i went poking around there after i posted and didnt find it ether
- kilrwail
The "vent pipe" under the accelerator pump (under the fuel inlet) is connected to the small outlet on the breather tube (your third question) with a semi-transparent plastic tube.
The Perpendicular line off the tee'd fitting (EGR lines) in front of the intake valve cover is connected to the thermoswitch on the intake manifold, which has the second line you mention in your fourth question that is connected to the carb near the mixture screw.
There's a third line connected to the intake manifold near its front, which is connected to a hard line leading across the engine to the rear of the EGR "valve/pot".
Maybe this will help:
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- manoa matt
Paul, send me an email ( matt.scarton@gmail.com ) I have some documents for the 32ADFA that show where everything hooks up.
Matt
Matt
