Intake manifold
geno58
Intake manifold
Post by geno58 »
I'm replacing the intake on my 1980 spider, Do any of the bolts go into a water jacket?
124JOE
Re: Intake manifold
Post by 124JOE »
i dont think so but the coolant for the choke goes in and will leak if not drained
vandor
Re: Intake manifold
Post by vandor »
The manifold is connected to the cooling system, so you need to drain it before you remove the manifold.
It's for manifold heating, not the choke. The choke has two separate coolant hoses.
geno58
Re: Intake manifold
Post by geno58 »
Yea, Draining the coolant was the first thing I did. That is what brought up the Question, because of the close proxcimity of the water jacket.. I suppose if I use some med. or light thread locker, that should fix any potential for leakage around the threads.
124JOE
Re: Intake manifold
Post by 124JOE »
use silicone
geno58
Re: Intake manifold
Post by geno58 »
Thanks for your thoughts
