Intake tuning switch?
jkn070458
Post by jkn070458 »
I'm working on my 1978 spider and just got all the exterior lights working yesterday. There are 2 wires on the driver side that I'm not sure where they go.
Wire 1 is brown/white. This wire has B+ when the ignition key is on.
Wire 2 is black/white. This wire is definitely a ground.
These wires are a perfect route to electrical connectors to some sort of component underneath the intake manifold. Can anybody identify this component or tell me where the wires go? The car runs great without these wires hooked up. Also does anybody have a component locator for the electrical system. Thanks in advance.
kmead
Your car is a: 1969 850 SC 1970 124 SC 85 X19
Re: Intake tuning switch?
Post by kmead »
The best diagram you will likely find is Brads:
http://www.artigue.com/fiatcontent/wiri ... g_1978.pdf
I can also email a similar one as a secondary reference just send me an IM
This should set you up well.
Karl
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
kmead
Post by kmead »
As for where the wires likely go:
Karl
1985 Bertone X1/9
