coolant leak
Italchic
coolant leak
Post by Italchic »
After changing all the hoses and clamps and driving for several weeks with no leaks, I put my spider in storage and then after a couple of weeks I noticed a puddle of antifreeze on the floor near the front center what could have happened?
124JOE
Re: coolant leak
Post by 124JOE »
go around and tighten all clamps
just dont over do it
if you find one already striped then thats your leak
azruss
Re: coolant leak
Post by azruss »
is the puddle directly under the waterpump.
blurple124
Re: coolant leak
Post by blurple124 »
azruss wrote:is the puddle directly under the waterpump.
Agreed, I would check the water pump. They tend to leak just before they go out completely. I had the same problem with my Jeep.
Charlie
1997 Jeep Wrangler TJ Sport
