Low compression numbers?
tinman760
Post by tinman760 »
Hello all. The car is a '73 Spider 124. I did a compression test on the 1592, and came up with 80, 76, 76, 80. I am wondering if these are low numbers, or acceptable. Curious to me that they are all in a acceptable range. Plugs are kinda black, may be from excessive fuel, pouring it down the throat to get her to go. Replaced fp, and soon to replace the carb, as the acc. pump seems to not be working. Maybe rebuild the old Weber. Any and all thoughts welcome. Thanks ciao
narfire
Re: Low compression numbers?
Post by narfire »
seem low to me. my stock 2L was around 140-150 and now with a bit different cams I'm 120-130.
Do you have access to a leak down tester. See if what compression you have leaks down quickly or slowly.
Kent124
Post by Kent124 »
Mine are 152 across all cylinders for a 2L.
tinman760
Post by tinman760 »
Guess I'll do a leak down test. Seems kinda obvious, now. Might save a complete overhaul, tho. Thanks.
kilrwail
Post by kilrwail »
Those numbers are low, but make sure that you test compression with the engine fully warmed up. It makes a big difference.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
leftfield6
Post by leftfield6 »
My 2L was around 120 when tested cold. Bumped up to 150 +/- when warm.
I have a leak down tester, but haven't used it yet.
engineerted
Your car is a: 1974 124 spider
Post by engineerted »
A weak battery and/or not opening the carb fully will cause low readings also. Did you check the cam timing, this will affect the Comp numbers also.
Ted
Ted
majicwrench
Post by majicwrench »
Does the engine run?? If the compression is actually that low, it is gonna barely run, if at all. The good new is all the cylinder are about equal. Leak down test would not be the first thing I would do, check cam timing first.
Keith
124JOE
Post by 124JOE »
yes you mat have jumped a tooth on the timing belt
that compression is too low for the engine to run, I'd start with checking the cam timing. It's odd to have fairly even numbers that low unless the cam timing is off
kilrwail
Post by kilrwail »
You might want to calibrate your compression gauge with another (known good) engine. Did you drop it?
Peter Brownhill
tinman760
Post by tinman760 »
The car runs when there is fuel present. Sounds pretty solid. The car has sat for years, tho. Gonna try the Marvel Mystery Oil trick, and check the cam timing also, before the leak down test. Thanks
majicwrench
If the engine runs strong you need a new compression tester.
Post by RRoller123 »
I believe that engine has a 9.8/1 compression ratio, making nominal compression around 144 psi. This assumes constant temp, (PV=nRT) but is pretty close to what would be expected. Higher is often due to carbon deposits effectively raising the CR, lower can be (among many reasons) because the carb throttle plate is not fully open when the test is performed. I made that mistake on my Honda CB350, was getting about 75 psi across both cylinders, then realized I hadn't opened the throttle fully. Ran it again and the numbers were in the 150's.
vandor
Post by vandor »
RRoller123 wrote:I believe that engine has a 9.8/1 compression ratio, making nominal compression around 144 psi.
Why would it have 9.8? US Spiders were between 8 and 8.5:1.
A newly rebuilt stock 8:1 CR engine will make ~150 psi of compression, one with 9.8:1 CR will be around 180 psi.
