New pads & now parking brake won't hold?
whiterabbit
Post by whiterabbit »
Fresh pads all around,new hoses,new compensator, and flushed the lines now I can't get the parking brake to hold. I screwed the pistons in with the line on top and bleed 'em like mad too. Compensator adjusted with load on the axle. Tightened the p brake cable thinking that was it but no dice. The p brake cams are moving at the calipers but I can still turn the wheels by hand with some effort. The p brake worked fine prior to the work.
I'm stumped! Any ideas? Carry a brick to throw under the tire? :lol:
vandor
Re: New pads & now parking brake won't hold?
Post by vandor »
Was the handbrake down when you screwed the pistons back? I did that once and the handbrake did not work. It took several times of moving the piston out and screwing it in before it worked again.
whiterabbit
Yea the handbrake was released/down when I installed the pads. I screwed the pistons in just enough to fit the pads. Should I pull the calipers and try to run the pistons out one turn?
Perhaps there's still air in the rear lines preventing the calipers from fully operating/closing on the rotors. :?
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
The parking brake works on purely mechanical, not hydrolic pressure. Do you have any resistance when you pull the e-brake handle? In other words, is the cable adjusted correctly?
Ron Luxmore
rlux2n2@gmail.com
131
Post by 131 »
The handbrake mechanism has always been a week link, the pads will hold better when they're bedded in. My car will hold when facing downhill, but I have to leave it in gear when facing uphill or it rolls.
Mick.
whiterabbit
Yea the cable is adjusted. I had the adjuster cranked in to the point you only had 3 clicks when you pulled up on the hand brake. I now have it slacked to the 4th or 5th click but you can turn the wheels with some good effort while it's on the stands and it'll roll down a moderate grade with the brake engaged. Hope the pads (ceramic) bed in a lil faster! :lol:
Thinking of adjusting the comp to allow a lil more braking to the rear, the car is lowered a good bit , doesn't have much nose dive and I've yet to lock up the rear brakes on very hard stops.
Guess I'll keep tinkering.... :roll:
124ADDHE
Your car is a: 1974 Spider Amalgamation with C40 Solex
Post by 124ADDHE »
Sounds like your pistons are corroding up or your e-brake cable has lots of corrosion and isnt transmitting much of your effort. I had 2 rear calipers nearly seized, a brake cable frozen on one side and it still held, didnt realise how bad the rears were until i went to rebuild everything, i knew it wasnt great (didnt hold the steepest grades without being in gear), but i had no idea how bad the rear circuit was! have a look, you may too be suprised :shock:
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
