WEBER CARBURETORS 34 DMS / 34 DHS 10
CESAR
Post by CESAR »
Has anyone any information about original jet specs of the listed carburetors?
Tks
manoa matt
Re: WEBER CARBURETORS 34 DMS / 34 DHS 10
Post by manoa matt »
Here is a little bit of info on the 34DMS including schematics and operation. The jetting specifications should be in the oficial Fiat Factory Service Manual.
http://www.artigue.com/fiatcontent/carbs/34_DMS.pdf
manoa matt
For the 34DMSA 1/100 fitted to 1974 1756cc spiders the jetting is as follows:
Primary venturi: 25mm dia, 1.45 main jet, 0.50 idle jet, F61 emulsion tube, 1.80 air corrector,
Secondary venturi: 27mm dia, 1.45 main jet, 0.60 idle jet, F61 emulsion tube, 1.65 air corrector
0.55 pump jet, 1.75 needle valve, 6.25mm float level
CESAR
Post by CESAR »
Thanks a lot.
I live in Brazil and this kind of car (Fiat 124 Spider) has never been sold here, thus, there's no related information...except in the Internet.
Tks again.
Cesar
