Page 1 of 1
Top Won't Close - It closed before
Posted: Mon Oct 03, 2011 3:26 pm
by jimmycakes401
When I brought the car home from the PO I put the top down to make it easier to work on. Now when I try and close it it gets about an inch or two away from the windshield and stops. I assume it has something to do with the wires? The first day I had it (a few months ago) it was fine. Could it have shrunk? It's been in my garage the whole time.
Re: Top Won't Close - It closed before
Posted: Mon Oct 03, 2011 6:35 pm
by Jimb
Can you not push down on the top with your arm while you hook the clamps and then draw it into position?
It's supposed to be a tight stretch.
Posted: Mon Oct 03, 2011 6:37 pm
by jimmycakes401
Pushing pretty hard
Posted: Mon Oct 03, 2011 10:47 pm
by vandor
I've never had it happen on old tops, but had several new tops that I was not able to latch for a day or two, and even after that only while applying force with one hand, while using the latches as levers with the other. After a few months of use it got easier.
If the top is well worn then I would look to see if the wires are routed correctly, or if there is some other mechanical problem keeping it from closing all the way.
Posted: Mon Oct 03, 2011 11:05 pm
by jimmycakes401
The top is really old. This is the first time it was off in probably 15 years.
Posted: Tue Oct 04, 2011 8:34 am
by jimmycakes401
I just used some brute force and pulled it down hard with the latches. It's up again. Whew. I need to get some sort of vinyl conditioner or something.
Posted: Wed Oct 05, 2011 10:46 pm
by sixcharlie
jimmycakes401 wrote:I just used some brute force and pulled it down hard with the latches. It's up again. Whew. I need to get some sort of vinyl conditioner or something.
Don't know where you live, but cold weather will have a lot to do with the ability of the top to stretch and close properly.
Posted: Thu Oct 06, 2011 7:34 am
by jimmycakes401
New England. But it's been in the 70s
It's a really old top. Has a tear or two. Is there a conditioner I can use to loosen up the vinyl a little or will just the warmth of the sun do that? Also, is it okay to store it with the top down? If it's going to shrink in the winter I don't want it pulling the vinyl more and tearing further. It's an ugly top, but I want to get it read to at least attempt to save me if a sudden blast of rain hits.
Posted: Thu Oct 06, 2011 8:40 am
by wikkid
303 Products for vinyl cleaning/protection/conditioning.
The sun will warm it up and that should also help.
Posted: Thu Oct 06, 2011 4:48 pm
by majicwrench
Tears, I had a convertable Firebird eons ago, and it had a decent top with one pretty good, long rip. Put a couple of iron-on jeans patches on it, worked good for years.
Tight, yup, mine is too.
Keith
