32/36 install
beachspider
32/36 install
Post by beachspider »
I mounted my 32/36 DFEV last Saturday. I actually had to go down to a 50 primary idle jet in spite of the fact my car is a 2 liter. It does still have the stock intake manifold. I had ordered a jet kit to go up in jet size for both primary and secondary idle as well as air corrector jets, but because I went down on the primary idle jet I've left the others alone. Wondering if I should still go up in size on air corrector jets? Runs, idles and drives good as is but slight backfire on shift when I rev to high rpms.
The real problem, however, has been the choke. The plates close and all, but no fast idle to matter how much I turn in the fast idle screw. Any ideas?
beachspider
Re: 32/36 install
Got the choke working. It turns out I had backed the idle speed way off. Wonder if this kept the fast idle from engaging. Still could go down a jet but going to check timing first. If it's advanced too much, could this affect how it runs with a given jet size?
Re: 32/36 install
definitely make all of the settings before changing jets. I'd have a hard time believing a 50 idle jet is too large for your motor.
bradartigue
Re: 32/36 install
Post by bradartigue »
On every 2000cc Spider I've worked on (dozens) the DFEV goes on without rejetting whether I've used the stock manifold or the 1800 manifold. Needing a smaller idle jet has me scratching my head, were you unable to lean it out using the mixture screw?
