car been sitting 6 years, it fires and runs for a second then stops, fuel pump is pumping, carb is getting gas when i push the throttle,. so possible the float
i just want to see if it runs half azz before doing any real changes
1980 fiat 2000
1980 fiat 2000
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: 1980 fiat 2000
if that was a first atempt,thats ok .was the carb leaking?
when they sit they get dryed out gaskets expand slow the next time should go well.
Re: 1980 fiat 2000
look at that picture, that a water pool sitting on top of the intake manifold, i seen it ther so i soaked it up with a rag and when turning it over, it would fire and back fire, so i looked again and the water is back
BLOWN head gasket or what ?
thanks
it on the carb side right up front by the timing belt housing
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: 1980 fiat 2000
double check all your hoses "coolant"
and the choke has coolant also.
Re: 1980 fiat 2000
ok thanks, the engine is dry other then that spot
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: 1980 fiat 2000
fuel pump dont work any more now. so it time to swap for a electric any ideas?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: 1980 fiat 2000
i pefer a mecanical one
Re: 1980 fiat 2000
thanks . does a 72 2l fuel pump work on a 80 2 l
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: 1980 fiat 2000
i think so
a carbed motor should take a swap no problemto a carbed motor
Re: 1980 fiat 2000
that what i thought, i have another fuel pump
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
