Diff
Diff
I have a '71 with what I beliebve to be the stock rear end. It has recently started to make some noise and appears that the pinion bearing has gone bad. Is it possible to replace this bearing and seal without tearing down the whole rear end? If a tear down is necessary, I think I would rather replace the whole rear end with a used one. Is there a difference between rear ends in pre '74 vs '75 or later? Mounting points for springs and control arms…….
Re: Diff
Rook,
We just had this discussion, look here:
http://www.fiatspider.com/f08/viewtopic.php?f=3&t=15
and there are others too. Try searching on rear end and differential.
I made the switch to a later rear with the 3.90 gear set and couldn't be happier. I'm actually glad now my original diff failed.
PM me if you want details on the switch.
Good luck.
Good luck.
- 124JOE
Re: Diff
the first link was right, but page 2 has alot of info on this.joe
- 124JOE
Re: Diff
the 4.10 is for scooting around town and pulling 5 grand on the tac at 65 mph
the 3.90 is better for travling less rpm at highway speed =better gas milage.joe
- 124JOE
Re: Diff
if you can drive around in 5th under 35 without it getting jumpy then you have the 4.10
i can almost startoff in 2nd
- 124JOE
Re: Diff
