carburetor question
carburetor question
I am considering upgradeing my carburetor on my 79 spider any thoughts on what I should get? will i notice a performance change?
- 124JOE
Re: carburetor question
yes a bigger carb will make a dif
one of marks empi carbs will do nicely
the 79 had the 28/32 adha carb "restrickded"
look for a 34/36
also youll want a 1800 manifold,as the 79 is made with smaller intake holesfor the carb.joe
look for a 34/36
I second the vote on the EMPI. Incredible difference and pretty much plug and play. Do it!124JOE wrote:yes a bigger carb will make a dif
look for a 34/36
- manoa matt
Why? Get a genuine Weber carb, its cheaper too (free ground shipping) 32/36 DFEV: http://www.webercarbsdirect.com/Weber_C ... rs_s/2.htm
Can I just replace the carb? Do you know where i can get an 1800 Exhaust?
Since I have a automatic choke how would I setup the electronic choke? What do I do with the water lines and all the vacuum lines? Does anyone have a picture of this area so i can get a better idea of what has worked for you?
- Your car is a: 1967 Fiat 124 Spider
you just need a key on only 12V power source for the electric choke. you can join the water lines to each other, or track down where they originate and plug them. (the better way to do it)
1964 Fiat Abarth 850TC conversion
1962 Abarth Allemano 1 liter Coupe
- kmac33
- Your car is a: 1974 Spider
Best pics of the carb I could find right now. I have a 36/36 on my 74 and am VERY happy with it.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
- 124JOE
"kmac33"]Best pics of the carb I could find right now. I have a 36/36 on my 74 and am VERY happy with it.
where did you run power from?for the choke
also where did you get it?the carb
Your paperweight of a carb you have now has a shutoff solenoid on it. The power for that should be just the thing. I don't know if the replacement carb will have a solenoid or not but if it does you should be able to splice into it.
Joel
Joel
- 124JOE
cool
He got it from us:124JOE wrote:"kmac33"]also where did you get it?the carb
http://stores.auto-ricambi.net/-strse-1 ... Detail.bok
BUT! I would NOT recommend it for a stock 2000 intake manifold. No point in putting a large carb on a very restrictive manifold. The 32/36 would work better, but that manifold is too restrictive for any carb.
With either carb I would strongly recommend converting to a 1800 intake manifold. Thant and one of these carbs will give you about 15 hp! That is enormous considering the car only had 86 to begin with! It will feel like a day and night difference.
check the parts for sale section here. people are always parting out the older cars. 1800 manifolds are not rare
