Where does the water drain?
donm
Your car is a: 1980 spider [carb]
Post by donm »
I know that rain water that happens to get by the rubber window wipes on the doors drains out the bottom of the doors, over the sill and onto the ground, but what happens to the water that gets by the rubber wipes on the rear windows? I can't really get a good visual down the window slot to see but I assume there must be a drain somewhere. And how would I make sure it's not blocked? I'm thinking that maybe some of you folks that have done complete interior restorations might have some information.
1979 Spider
2001Saab SW
2004 Saab Aero
WYSpider
Re: Where does the water drain?
Post by WYSpider »
Seems like I saw a drain in the space where the convertible side window retracts when the top is folded down.
124JOE
Post by 124JOE »
yes they have drain pans,rubber funnels and rubber tubes that go thru the bottom
very close to the door jam
azruss
Post by azruss »
The drain is just as described. The drain hole in the sheetmetal is between the back seat and the wall. the rubber hose goes in that hole. that drains into the unibody outrigger tube. crawl under the car and make sure all the drains along the bottom seam are free and drain properly.
donm
Post by donm »
The only thing I am able to see are 2 slots under the rocker panel so I guess that's where the water drains out?
1979 Spider
2001Saab SW
2004 Saab Aero
azruss
Post by azruss »
there should be 4 of them on a side, spaced evenly between the 2 jack points.
