Specs for the motor:
1756CC
4mm dome pistons(~9.8:1CR)
Alquati 42-82 cams
Weber 38ADL
Lightened flywheel
Allisons automotive aluminum radiator
Millers Mule Adjustable cam pulleys
Early 4-2-1 exhaust manifold with straight pipes to ANSA muffler
Back on topic, the car has about 1500 miles on it now and has been running pretty well although I've been having trouble getting the mixture/tuning of the carb correct. The AFR is all over the place, and the idle is VERY lumpy up until the carb transfers from idle to main circuit(you can see part of it in the photo). It also appears to have a slight miss at idle. Once the car transfers to mains, the AFR drops way off the map. It appears to go below what the dyno sniffer was able to even pick up(flat line at ~3000 rpm) it then slowly climbs up after awhile. Does this indicate the need for larger main jets? smaller air jets? I'm a complete novice at carb tuning and dont really know how jetting theory works.
WP_000333 by boogiedude, on Flickr
Also notice the "roughness" of the power/torque curves. Is this normal? product of aggressive cams? detrimental to performance? tunable?
Video of the run(forgive the crappy audio, shot with my phone I may get footage off of a friends GoPro at a later point):
http://youtu.be/6Mc_NWmieB8
can't figure out how to embed?
Any tips/advice?
