Fan Belt Chirping
yap123
Fan Belt Chirping
Post by yap123 »
Howdy,
I have a noise coming from the fan belt. It sounds like a bird chirping. Is my belt too loose or too tight or is it a bad bearing?
Clint
mbouse
Post by mbouse »
moren likely it is the alternator or the water pump.
small noise, or very annoying big noise?
suggest you just keep an ear out for changes in the volume or frequency.
nickfury
Post by nickfury »
I had this problem with my nissan truck turned out to be a leeky exaust manifold. it is like driving a bird
hopes this helps
Dave
yap123
Post by yap123 »
I'm pretty certain the sound is related to the fan belt spinning. After the warms up a bit, the bird chirping noise starts.
