what can i do to a 1438 to boost up the hp? i have a 1608 here too, so what can be done, i did read that the 1608 head can work on the 1438 and increase it , so with out doing any internal work, would that be it ?
just asking
engine
Re: engine
You could put the 1608 top end on it, but you would be a lot better off to freshen up the 1608 and drop it in, it is a much better package than the 1438. The 1438 can just barely get out of it's own way, the 1608 can really move, at higher speeds it is vastly superior. PB
Re: engine
I would rebuild the 1608, put a decent header/exhaust system on it, get good manifold and properly match the ports to either a 34 ADF or 32/36 carb. If you can, use a Marelliplex or other electronic ignition. This will really make a big difference over stock trim without going into pistons/cams, etc.
- azruss
Re: engine
the 1608 has a much stronger bottom end. (i'm not talking performance)
Re: engine
ok thanks, that what i sorta had plans for , but i was just reading and seen others use the 1408 and modify that
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- divace73
Re: engine
go the 1608 with twin IDF carbs and 4-2-1 exhaust just like the Euro version
Below is an example out of a BC coupe (minus original exhaust)
Cheers David
see my >>You tube channel<<
Re: engine
i dont have twins, but that nice
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- divace73
Re: engine
They come up on ebay every now and then, an example in Oz
http://www.ebay.com.au/itm/Twin-Weber-4 ... 1e662bd492
If you can find the complete set up would be ideal, eg linkages and turtle back air cleaner
Cheers David
Re: engine
how much is 500 in usa? i just seen that with the site u have here
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: engine
i got a bid on them
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: engine
hey guys and gals
so witch is better the 1608 or the 1756 just wondering.joe
Re: engine
1800 will make more power and like the 1608 has a good bore to stroke ratio, IMO, 1438 is just too small, 1592 has a bad bore to stroke ratio. PB124JOE wrote:hey guys and gals
