Thermostat twisted in the housing
ORFORD2004
Post by ORFORD2004 »
Since i removed my engine to put the new one, i removed the thermostat to find that he was twist inside with all port open.
That's why it was so easy to burp my system lolll!!!! :cry: Is that a regular problem?
courtenay
Re: Thermostat twisted in the housing
Post by courtenay »
Mine had all the ports open as well. As near as I could determine, the only impact was that the water was always circulating through the radiator so it took longer for the engine to reach a normal operating temperature but was fine once it did.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
124cso
Post by 124cso »
I'd go and buy a new one, especially living in an cold climate. If you engine is too cold, it will not run right and will use extra fuel.
ORFORD2004
Is Quebec supposed to be cold :?: :?: :?:
And since my fuel pump is not working for now, the car is very good on fuel :D
124cso
Post by 124cso »
ORFORD2004 wrote:Is Quebec supposed to be cold :?: :?: :?:
A bit cooler than in the Mediteranian isn't it ?
If it ain't goin, and you don't want to take advice, why bother to ask about thermostat ?????????????????
ORFORD2004
The question was: Is that a regular problem not if i can leave it like that. I will replace it for shure
124JOE
Post by 124JOE »
it sounds like it froze
so thats normal for us BUT!
if youve seen it drill a 1/8th hole in the new thremostat.joe
