Valve shiming on high perf engine?
coise
Post by coise »
Could any body tell me what gap should I leave when I shim my valves on my high perf engine?
I heard 0.010 to 0.012 for the intake and 0.012 to 0.014 for the exhaust.
Thanks.
Coise
narfire
Re: Valve shiming on high perf engine?
Post by narfire »
What cams are you using?
I have a set of Marks FI 274's in my car and they came with a note explaining the overlap ect. and also the clearances..
10 thou intake and 10-12 thou exhaust.
Chris
coise
Post by coise »
The engine is a 1800 with 34adf carb high compression pistons bigger valves (stainless) and a Vicks stage 1 cams (40-80/80-40) and a 2 1/4 inch exhsaust line.
thanks.
coise
131
Post by 131 »
coise wrote:Vicks stage 1 cams
If they supplied the cams, they should have supplied the specs. They'd be the ones I'd be asking this question of.
Mick.
