Exhaust stud length
barnesjtsl
Your car is a: 1979 Spider
Exhaust stud length
Post by barnesjtsl »
79 2000
From what I can tell the stud size is M8x1.25.
Can anyone tell me how long the exhaust studs are? The one in particular I am needing to heliocoil is the one on the top end closest to the timming belt.
barnesjtsl
azygoustoyou
Re: Exhaust stud length
Post by azygoustoyou »
None of yours come out. I can take most of mine off.
5.6cm with 2cm in the block on my 1800 eng.
SouthSwedeSpider
Post by SouthSwedeSpider »
I just had some of my studs replaced, and I think the new ones were about 50 mm long (20 mm thread, 10 mm flat, 20 mm thread). Worked fine. Just check the depth of the hole in your head :lol: , the threaded part of the stud has to be a little shorter.
