I am going to remove the exhaust manifold on my 78 and replace the gasket. Are their any tricks or areas I need to be aware of? A friend suggested using a pentrating oil on the bolts to aid in the losing and to keep me from snapping off the heads. I was planning on do this with the engine still in the car. I assume this should not be a problem. I also read that the torque on the bolts should be 18ft/lbs and I should work from the center and go out to tighten the bolts.
Ed Clark
404-234-7366
Removing Exhaust manifold any tricks
- Your car is a: 1978 Fiat 124
Ed Clark
404-234-7366
Ed Clark
404-234-7366
- 124JOE
Re: Removing Exhaust manifold any tricks
all should go well-i hope
.joe
.joe
- TulsaSpider
No tricks. Straightforward. Replacing them. Now you run into some things to do.
Just soak the nuts with some wd-40 a day or 2 before. Not hard.
