crank case vent
124JOE
crank case vent
Post by 124JOE »
hey guys ive been getting some oil up the tube
making my carb very dirty and smelly
any help?
124ADDHE
Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: crank case vent
Post by 124ADDHE »
Is your oil level high? Some people run this over a bit. How many miles on your motor, maybe its blowbye from worn rings, letting pressure into the motor? I would start by taking apart the whole assembly and cleaning it throughout, then see if you still have the problem..maybe the orignal air-exchange of the breather is no longer sufficient?
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
velozi
Re: crank case vent
Post by velozi »
Add a flame trap to the long hose.
