Fan went on finally! Check your connectors
I was really confused as to why my new spal fan wasn't going on. I first made sure that the bottom of the rad was hot, then I checked the wiring diagram and made sure the wiring was connected right. It turned out the bullet connector going from the grounding pod to the fan rad sensor wasn't pushed in far enough.
