weber 32 adf manual
ragtop2000
weber 32 adf manual
Post by ragtop2000 »
I have recently acquired a Weber 32 ADF carb, it was reconditioned and did not come with a manual. I have it installed and it is a vast improvement over the stock 79' carb. My only problem is that I am having trouble setting the fast idle. When I cold start the car I have to manually push the accelerator briefly to keep it running till it warms up. If someone could send me a manual or a diagram pertaining to the fast idle adjustment I would appreciate it. This is an ADF not an ADFA if that matters. The diagram/manual would also help me make sure I have everything connected correctly because I also disconnected all the emissions stuff.
rlux4
Patron 2022
Patron 2022
Re: weber 32 adf manual
Post by rlux4 »
This is on brad Artigue's site:
http://www.artigue.com/fiat/carbs/32_ADF.pdf
If you havent' checked his Fiat site out, you should. It's a treasure trove of great info.
Ron Luxmore
rlux2n2@gmail.com
manoa matt
Post by manoa matt »
If you send me an email I can send a PDF of the workshop manual for the carb plus a few other PDF documents that pertain to that particular model carb. matt.scarton@gmail.com
