Zerk Fittings
tartan18
Your car is a: 1975 Fiat 124 Spider
Zerk Fittings
Post by tartan18 »
Several questions:
1. Is there more than the one zerk fitting that is part of the drive shaft?
2. How much grease should be squeezed into the fitting (one, two or more hand pumps)?
3. Any other suspension/chassis grease points?
Thanks.
Jim MacKenzie
1975 Fiat Spider
baltobernie
Re: Zerk Fittings
Post by baltobernie »
1. No
2. 2.756 pumps
3. No
Re: Zerk Fittings
some brands of lower ball joints have zerk fittings. Other items to check the fluid level of would be the steering idler and steering gear box
tartan18
Re: Zerk Fittings
Post by tartan18 »
Thanks gentlemen.
Jim MacKenzie
1975 Fiat Spider
124ADDHE
Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: Zerk Fittings
Post by 124ADDHE »
all 4 bj's on my spider have a plug in the bottom to be removed, a nipple installed and greased.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
