Clutch Pedal Return Spring Goes "BOING!"
opus10583
Your car is a: 1978 CS1
Post by opus10583 »
HI,
After searching around here a bit I'm inclined to accept the noise my Clutch Pedal Return Spring (CPRS) makes in the last 10mm of travel on return, a cartooney spring "BOING!", despite indicating something metal-on-metal binding somewhere, is not a critical issue, but it sure is a quality of life issue and I'd like to fix it.
Has anyone here had any success short of removing the spring?
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
fiat218
Re: Clutch Pedal Return Spring Goes "BOING!"
Post by fiat218 »
my 69 does that once in a while. i never did look and see what going on
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
azruss
Post by azruss »
i suspect that wear at the ends is binding the spring slightly and then releasing it. the proper solution would be to pull the spring and fix the wear spot. may try to lube the contact point.
fiat218
Post by fiat218 »
wonder is is hard to just replace
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
azruss
Post by azruss »
replacing does require some technique. the secret is to stretch the spring out while it is on the car and insert coins or washers in the coil gaps. this saves body parts and bodily fluids when reinstalling.
fiat218
Post by fiat218 »
that makes sense
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
