turning signal cam
fiat218
turning signal cam
Post by fiat218 »
can a turning signal cam be replaced on a 69 124
the plastic part under the steering wheel
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
manoa matt
Re: turning signal cam
Post by manoa matt »
I'm guessing its not self canceling, or will self cancel in one direction but not the other. The problem is the spring for the floppers. That piece can be switched out, but the whole mechanism must be disassembled in order to do so. The two rivets on the sides must be drilled out so the mechanism can be separated. Each of the lever discs will have a spring and a small steel detent ball that will come out upon removal and require careful placement during reassembly.
fiat218
Post by fiat218 »
that spring thing broke, that why i am wondering is that piece can be replaced,
or is it all on the arm assembly? OH so it is all attached to the blinker arm?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
There is another spring for a pin that is within the steering wheel hub. The pin engages the collar. The collar has a raised area that engages the self canceling floppers.
Now that the two modes of failure have been identified (via springs in both cases), you need to determine which one is at fault.
fiat218
Post by fiat218 »
here is what happend, i put the cowel on around the steering whhel and when i turned the steering there was a click and a bad noise, well i left it be , then i took the cowel off and there was broking piece in the cowel with 2 small springs
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
Pictures, pictures, pictures. please.
fiat218
Post by fiat218 »
i dont know how to post a picture on this
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
