EGR Valve removal?
KalamazooJohnny
Your car is a: 1976 spider 1977 spider 1965 1100D
EGR Valve removal?
Post by KalamazooJohnny »
I took out my EGR valve and bought a plug to put there instead. When I took it out, engine coolant ran out all over. Is that hole suppose to be full of coolant?
"Get used to people calling it an MG. Hardly anybody recalls Fiats, but people remember MGs because they once saw one on fire." -Corey Farley, Autoweek January 20, 2003
76spider
77spider
65 1100D
lanciahf
Re: EGR Valve removal?
Post by lanciahf »
What year spider?
KalamazooJohnny
77 spider 1800 with carb.
76spider
77spider
65 1100D
Glasair180
Your car is a: 1977 Fiat 124 Sport Spider
Post by Glasair180 »
Which holes did you plug? (where did you get them?) I have a '77 and have been searching for plugs for the exhaust manifold and for the intake manifold but it is an odd metric size so I have had no luck yet. I have removed them to measure the threads and there was no coolant. I don't see how there would be.
1977 Brown Fiat 124 Sport Spider Daily Driver
1977 Red Fiat 124 Sport Spider Project
1996 Silver Moto Guzzi 1100 Sport
2000 Black Moto Guzzi 1100es Quota
Fun Italian Artistic transportation
the egr can't have coolant unless you removed the thermovalve in the intake manifold. That is a water jacket, hence the "thermo" part of the name
KalamazooJohnny
Yeah, my terminology is off I guess. I took the thing with the 2 tubes out. It sits on the center of the intake manifold between the carb and the engine. It is a metric 18 x 1.5 thread I think. I bought the plugs at Advance Auto. They are oil plugs. So Mark, am I not suppose to remove the thermovalve and plug it? There is suppose to be coolant under there? The thread did not look like a tapered pipe thread, so I put a little gasket seal on the threads when I plugged it. Am I doing something wrong by removing that thermovalve?
76spider
77spider
65 1100D
majicwrench
Post by majicwrench »
There is supposed to be coolant under it. Plugging it fine, sealer is fine, if you live somewhere that does not check such things.
Keith
