28/32 ADHA Help
79spider2000HMSL
28/32 ADHA Help
Post by 79spider2000HMSL »
Hello,
I have a 79 with a weber 28/32 ADHA on it. I plan to switch to an ADF eventually, but would like to get the current carb working better until that point. When I bought the car the EGR valve had been removed, and a bunch of lines, some from the carb and some near the carb, have just been plugged with bolts. I have had no luck finding help in terms of which line should go where??? There is a small amount of fuel/oil spraying from an unknown location near the carb. And I would also like to know where to connect the air filter to control valve line? I am not 100% on the correct connection point on the carb.
manoa matt
Re: 28/32 ADHA Help
Post by manoa matt »
Send me an email, I have a few pdf diagrams that will help. matt.scarton@gmail.com
