how can I tell the differance? 1438cc or 1608
Jeorge
Post by Jeorge »
How can I tell the differences in the Motors Just picked up a 1971 fiat 124 spyder also what would the HP be on that motor?
Daniel
Re: how can I tell the differance? 1438cc or 1608
Post by Daniel »
Hi Joerge Welcome to Fiat Ownership !
Here is the Block Model number for a 1438 is 124AC3.000 sorry i dont have the number for 1608 on me but
the 71 should come with a 1608 .
Hope this helps
Daniel
aj81spider
Post by aj81spider »
There's a number stamped above the oil filter on the engine block. A 1438 will have a number that starts with 124AC (e.g. 124AC.040). A 1608 will have a number that starts with 125BC.
You should do a search on the Mirafiori Engine Manuals. There is good information in them on how to identify various engine types.
ventura ace
Post by ventura ace »
If you are not able to read the markings due to rust, paint, grime etc., there are 2 visual dfferences. The height of the block from top to bottom is just under 10" for the 1438cc, and about 10.5" for the 1608cc. it's not very easy to make this measurement unless everything is off the block, however.
The easiest visual difference is the cranshaft pulley. When looking at the front of the crankshaft pulley on the 1608cc, you will see a big nut (larger than 1") that holds the pulley in place. When looking at the 1438cc engine, you should not be able to see the nut that holds the pulley in place, since the pulley includes a centrifugal oil filter that incorporates a cover on the front of the pulley. The cover is held in place by 6 small screws (6 mm thread, 10mm socket size).
Alvon
