Bearing Cone Position in Hub
WYSpider
Post by WYSpider »
I removed the hub from my Fiat to install Whoa brakes. Unfortunately the outer bearing cone slide out of the hub before I had a chance to see how it was originally positioned.
I am assuming the narrow part of the cone (top of cone in image) slides into the hub first. Is this correct?
81SPIDERMATT
Re: Bearing Cone Position in Hub
Post by 81SPIDERMATT »
yes
WYSpider
Post by WYSpider »
Many thanks Matt :)
