Anti-Seize
WYSpider
Anti-Seize
Post by WYSpider »
I have read about people using anti-seize to use on nuts. Is this just teflon tape like plumbers use on fittings or something else?
divace73
Re: Anti-Seize
Post by divace73 »
It's usually a paste like material in a tube or the like.
Cheers David
see my >>You tube channel<<
mdrburchette
Re: Anti-Seize
Post by mdrburchette »
You should at least be using this on the threads of your spark plugs to make life simpler down the road.
Re: Anti-Seize
besides spark plugs, it should be used on all exhaust nuts and bolts and any bolt that goes into aluminum
131
Re: Anti-Seize
Post by 131 »
I've used it "sparingly" for decades on the back of brake pads to prevent squealing.
Mick.
