I'll be putting a 34 dmsa on a 1608, single plane intake as well, but I was going to use an electronic dist and am wondering if the dmsa has a vacume port that would work for the vacume on the dist.
I believe I'm going to be learning about carbs shortly as I don't really know what all those outlets are for. Currently the PO has some plugged.
Chris
dmsa carb and vacume port
- divace73
Re: dmsa carb and vacume port
I imagine if the vacuum port is prior the throttle butterfly like the FI cars, then it may be okay?
Cheers David
see my >>You tube channel<<
You can find some information on your dmsa here http://www.artigue.com/?page_id=62narfire wrote:I'll be putting a 34 dmsa on a 1608, single plane intake as well, but I was going to use an electronic dist and am wondering if the dmsa has a vacume port that would work for the vacume on the dist.
Chris
spiacente, non posso parlare l'italiano.
But I believe the carb does have a vacume port thanks
Chris
Chris
