New fuel pump
mx266
New fuel pump
Post by mx266 »
Put in a new electric fuel pump , just wondering how many pounds of pressure should there be!
Re: New fuel pump
carb or fi?
mx266
Re: New fuel pump
Post by mx266 »
Carb ! Sorry bout that
Re: New fuel pump
you only need 2-3 lbs of pressure. If you have more than 3, you may need to install a regulator
mx266
Re: New fuel pump
Post by mx266 »
Thats what i thought wasn't sure. Thanks for the info i'll most likely get a regulator to be on the safe side.
