Coolant
Coolant
I have seen this subject discussed on this forum previously, but specifically not this item.
I have just replace my carb and intake and exhaust manifolds, I drained the coolant system.
All is well except I have an air lock at the bootom hose to the external thermostat.
On IAPs website their tech bulletins states that If you have a SAVARA thermostat which is my case.
Then you may want to drill a 1/8" hole inside the tstat lower hose wall to allow small amount of coolant to go from lower to upper. IAP has a diagram of this .
Has anyone had any experience in doing this operation?
Should I follow this procedure,
or should I drain the system again and start over by filling a section at a time.
Note I installed the t fitting from prestone at the top of the heater hose.
drilling the hole is a good idea, I've been doing it for years. Besides making it much easier to fill the system, it's sort of a failsafe in case the stat ever sticks shut. Believe it or not, that tiny bit of flow will keep the engine from melting down. It will still run hot, but not cause engine failure
Mark
I drilled the hole this morning and refilled system, seems to have solved the problem
thanks.
I have another question.
I completed the carb change on my 79 spider I used a 32/36 DFEV weber.
I have an automatic transmission.
When I took it for a test ride the accleration was very good, however my transmission did not change until I hit about 5000 RPM it almost feels like I have a standard tranny. Also I feel the same thing when slowing down I actually feel the tranny shifting into lower gear.
is this normal.
Again accleration is great.
Tony
thanks.
is this normal.
Tony
Mark
In reference to my automatic 79 spider
hooked up that vacuum line this AM
Same problem persists, Tranny is not functioning.
I m sure it is this dent cable you refer to, the Manual also states a kickdown cable which is prob, the same thing. But for the life of me I can not find this cable and where it goes
Any advice as to where I should be looking and where it connects to would be greatly appreciated.
There is no fiat mechanic in our area that I know of TRhat I can ask.
Thank you
Thank you
Mark,
I had no idea we were discussing an automatic transmission when I talked Tony thru the carb change. therefore, i made no mention of hooking the kickdown cable back up. he went with a 32/36 weber w/out any superfolous ports; just fuel and dizzy vacuum. he also created all new vacuum connections at his "new" intake manifold. it is possible that he capped off the trans tube, in addition to or rather than a fuel return line. maybe a picture would help?
Tony,
Sorry, man. I thought we were working on a manual trans vehicle. Is it safe to say that the tranny operated correctly BEFORE the carb change? if so, then the issue is morenlikely directly related to either the kickdown or the vacuum tube.
Tony,
Mark
I believe I found the cable it is attached to the linkage, thats why I did not see anything loose. however it was loose but still attached to the carb linkage.
In trying to tighen I broke that little plastic fitting it runs through which is attached to the carb linkage.
I need to get another, any ideas.
also I need to put something on the cable at the end of that plastic fitting so that it will engage when the acclerator is pressed.
Thanks for your help and also Mikes.
It has been a larning experience.
you'll have to get creative to attach the cable, probably have to go to the hardware store.
Since you changed manifolds, you may not have a manifold vacuum port for the tranny. It's critical that you use manifold vacuum and not ported vacuum for the modulator, otherwise you'll have late, hard shifts
