blown head gaskets, how much $$ to fix
scootersbellissimo
Post by scootersbellissimo »
Looking at a running 76 Fiat spider with a blown head gasket, (owner says) How much should I expect to pay to have a professional do this repair? :?:
puddin
Re: blown head gaskets, how much $$ to fix
Post by puddin »
i suppose if it's only a blown gasket $200-$300. but be concerned with what caused the gasket to blow==
majicwrench
Post by majicwrench »
There are a LOT of things that can cause the price to go up or down. If someone came into my shop and asked I would not give them an estimate. THere is no way to get even close with tearing it down first. That said, since you are not my customer :) I would certainly sell a timing belt at the same time, expect to change oil, at least bid the job with a head surface, it may not be needed. Also on a car that old I would just about bet there is gonna be some sort of complication along the way. I'm in the boondocks and charge $50 per hour, and if I HAD to say and price, I would say $600. But again, there are LOTS AND LOTS of things that can drive that up, or down.
YMMV
Keith
it's very rarely that you can just lift off the head and replace the gasket without doing other work. That is a recipe for another failure in the near future. If the head is warped (expect it with a failed gasket), surfacing requires removing the valves
narfire
Post by narfire »
A friend that helps me with the heads, would charge a hour or two to take it apart and then would have a better idea as to what the final tally would be.
scootersbellissimo
Thanks all! That helps a lot.
