how tight should the hub nut be
81SPIDERMATT
Post by 81SPIDERMATT »
new bearings in the front...inner and outer...how tight should the hub nut be tightened and also it looks like there is no cotter pin....i think i am supposed to hit the nut with a punch or a big flat head screwdriver at the indents .... is thatt right.... thanks in advance.... matt
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Re: how tight should the hub nut be
Post by v6spider »
According to my FIAT Service Manual, tighten the hub nut to 14.5 ft lbs and spin the hub several times in both directions to seat the bearing, then back it off and tighten to 5 ft lbs. Stake the nut with a punch and hammer both sides. FIAT make a special tool for this, but I have never seen or used one.
Rob
http://www.v6spider.com
81SPIDERMATT
perfect..... thank you very much
