idle with help of choke only
mik
Your car is a: 1969 124 Spider Convertible
Post by mik »
Could someone help me troubleshoot? My '69 124 does not start with the turn of the key, takes a little coaxing. New battery. Engine turns fine,I usually start it periodically, it's not driven daily. Once started I push the choke in gradually, but after a time I think car should run without the choke and push it in all the way the engine dies. It restarts right away. Engine is stock 1438cc, no upgrades or modifications. I appreciate the info this forum shares. Thanks.
Re: idle with help of choke only
if it sits alot, the idle circuit in the carb is probaby gummed up
