Hi can any one help me out don't know how to remove the clip inside the piston that hold the pin in place also need to know how to install it any special tools needed or something simple to use. Will be taking off connecting rods so I can replace the top bearing on the rod.One more question do you punch out the bearing at the top of the rod, to install just push in.
Nick
clip on piston
- Your car is a: 1970 128
Re: clip on piston
Re: clip on piston
Thanks fiatfactory for the adviseon how to remove the clip.
Nick
Nick
