83 Pinn heading to warmer climate
HazPin
Post by HazPin »
Hello all,
I just swapped my Piano and a server rack for a 83' Pinn that my neighbor had sitting for 3 years.
I'm in Canada at the moment and am heading for Phoenix ASAP trying to outrun the snow :D
It was parked for so long because he couldn't keep it going, they changed the fuel pump/filter and she ran a few days and stalled near our houses and has sat since.
To not get too long here, I have cleaned out the tank, checked the pump/filter/lines/regulator ~ it would fire but die off in a few seconds... Seems when I unplugged the Throttle Positioning Sensor it fired up right away :) I tested it (worked fine) put it in place, turned it too close the circuit, tightened it down and Phoenix here I come! :lol:
My pal wasn't too happy to realize he missed out on 3 yrs worth of driving cause of this :(
The car needs some body work in the usual places (rusted through) - anybody have a name in the Phoenix area?
I am sure I will ask more of all you, so thanks in advance and will write again once Im in the warmth :D
Harrison
Exit98
Re: 83 Pinn heading to warmer climate
Post by Exit98 »
Hi HazPin,
So you are driving it from Canada to Arizona? That should be an interesting trip. When are you leaving?
Keep a journal we will all want to hear the stories.
Good luck.
