aux air valve cross reference
backyardbill
Post by backyardbill »
I am trying to source na AAV, auxillary air valve, for my 1980 FI spider. Is the one on this car used on other vehicles like VW, Mercedes, BMW, etc. A cross reference would be nice. Thanks.
Fiat1980spyder
Your car is a: 1980 Fiat Spider 2000 Fuel injected
Re: aux air valve cross reference
Post by Fiat1980spyder »
I got one from a vw type1 which i think also works on the rabbit works great 2 years in.
Bought it on ebay here is something that should work:
http://cgi.ebay.com/ebaymotors/VW-GOLF- ... ccessories
Bosch 0280 1401 45
a bit high for the valve used got mine for $25 shipped. Worse case go on a forum for the older beetles with the L-jet system and ask there. Reference numbers you can use the one you have and input it into ebay or a search engine i am sure you will find something.
People might use different names for the valve such as Auxiliary valve,idle air valve, idle valve, air valve,idle compensator
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Trey
even though they look the same, there are some different operating parameters for the valves. Substituting one from another make could cause the cold idle to be incorrect
