Air Pump
1976sport
Air Pump
Post by 1976sport »
I am going to replace the timing belt on my 1976 and remove the air pump, can someone tell me if I need new "cam timing gears" replaced with those that do not hav ethe gear for the airpump belt? Would it be out of balance if I did not ?
If these need to be removed HOW?
Re: Air Pump
you can use the cam gear without the air pump belt on it
